Question About Pricing A Used 3500i
  • Happy Copier
    • Mar 2019
    • 49
    Hello everyone!!!....Let's say you've got a Kyocera 3500i with around 400k on it. It's making great copies and fuser looks great, no problems at all. It would be put immediately under a maintenance agreement so seller would be responsible for any future repairs.
    What would be your price to sell it?
    How about rent on a copier in that size range and is around 7 years old, what would something like that rent for where you are?
    Thank you so much for any help!!
  • Tonerkiller
    • Oct 2012
    • 668
    Re: Question About Pricing A Used 3500i
    Put it this way, parts will be unavailable in about 2 years.
    • copiertec
      • Jan 2016
      • 2205
      Besides the parts issue that tonerkiller mentioned, it also has limited SMB scanning capabilities and no technical support from Kyocera. Our company stopped selling these units several years ago due to such issues.
      • Happy Copier
        • Mar 2019
        • 49
        Are you saying the SMB is limited because it is 1.0? I know you cannot scan to a thumb drive from the 3500.
        Sent from my SM-G930V using Tapatalk
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1883
          You can scan to a flash drive, and if you get the local firmware from Kyocera, you can scan using SMB V2 and 3 I believe.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • mtcchuck
            • Oct 2016
            • 50
            you can still get tech support on the TASKalfa 3500i. Called this week
            • Happy Copier
              • Mar 2019
              • 49
              Are you sure about it scanning to flash drive? I read the specs a couple days ago and it did not say scan to USB, I looked at the 3501 and it had USB listed. I was trying to answer the question if it could scan to a flash drive.
              • tmaged
                • Oct 2008
                • 1883
                [QUOTE=Happy Copier;774330]Are you sure about it scanning to flash drive? I read the specs a couple days ago and it did not say scan to USB, I looked at the 3501 and it had USB listed. I was trying to answer the question if it could scan to a flash drive.
                Yes, it will definitely print from and scan to a USB/Flash drive.
                Hope that helps !
                -Tony
                www.dtios.com
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  With 400k its a dubious refurb. Maybe 2k tops
                  • Happy Copier
                    • Mar 2019
                    • 49
                    When these machines can make it to a million copies, why would you stay away from that number of copies? Thanks for your opinion!
                    • JR2ALTA
                      • Feb 2010
                      • 2033
                      I didn't say stay away. I gave a price based on age and number of copies. But I am not in sales so take it with a grain of salt.
                      • Happy Copier
                        • Mar 2019
                        • 49
                        Excuse me, I misunderstood. Thank you
                          • 23007
                          I would structure it as a short term rental month-by-month. That way when you can't fix it, you can just drop the agreement and resume with some other piece of equipment.
                          As far as I'm concerned this is not an issue of suitability of equipment, it's an ethical issue. Can I live with selling a piece of equip that can't be serviced in a couple years. This solution covers both. =^..^=
                          • Scott
                            • 196
                            Agree with Blackcat
