multiple document feeding on ADF of Kyocera KM 2035
  • bejoyjohn
    • Nov 2008
    • 45
    Hi
    Have a KM 2035 ADf multiple doc feeding . I did all types of cleaning but is not working. Does changing the spring on the feed roller stem work? please help
  • bejoyjohn
    • Nov 2008
    • 45
    Re: multiple document feeding on ADF of Kyocera KM 2035
    Originally posted by bejoyjohn
    Hi
    What mechanism is there for preventing double feed on adf feeder in this model?
    • Santander
      • May 2009
      • 768
      It is called the retard roller/pad.
        • 22703
        Is there anything special about your originals?: NCR? thin paper? staple removed or nested originals?
        • bejoyjohn
          • Nov 2008
          • 45
          Normal plain papers I tried. It is double or multi feeding, I will try changing the retard pad and then see.
            • 22703
            If you're still getting multiple original feeds with new separation, you can try installing a stronger separation spring. I had a customer that was running color prints from the Xerox Phaser (crayon) printers. Only those originals multiple fed, and it's no surprise with that thick layer of waxy stuff on the paper. =^..^=
