Kyocera FS-4200DN Smudge on paper
  • gosztidj
    • Jul 2019
    • 2
    [Misc] Kyocera FS-4200DN Smudge on paper
    Hi. We have some problem with printer. I attached the picture from problem. I tried cleaning, but it was not better. What can i doing right now? Thanks.
    • 23009
    Re: Kyocera FS-4200DN Smudge on paper
    What is the repetitive interval (I can't measure from a photograph)?
    I'm going to guess 29.9mm ... primary charge.
    • pasek2051
      • May 2019
      • 24
      Stawiam na pcr
      • francisco
        • Nov 2009
        • 168
        [ATTACH=CONFIG]43063[/ATTACH]
        change or clean charge roller MC-3100
        • gosztidj
          • Jul 2019
          • 2
          I tried cleaning and it was worked, but this phenomenon came out again after the printing of some copies.
          • francisco
            • Nov 2009
            • 168
            you have to change it.
            • gordie
              • May 2008
              • 83
              Hi
              I have had several of these printers with this problem and it turned out to be faulty fuser unit.
              Regards Gordie,
              sigpic
                • 23009
                Please measure be for randomly swapping in parts. =^..^=
                  they never listen...
                  • Ropariva
                    • 679
                    Dude...looks like the Teflon is torn on the fuser. Have you looked at this?
                    • JR2ALTA
                      • Feb 2010
                      • 2033
                      So why should we give 2 s***s? What can transfer onto a page? Image unit, dev unit, fuser.
                      Either a "tech" who can't identify which of THREE components is the cause or an end user who can't order or replace the parts anyway.
                      • yourownfree
                        • Dec 2007
                        • 474
                        replace the transfer roller. Above techs are how I feel about it. if you fold your paper from one mark to the next you will see the diameter of the roller you are dealing with. There are way too many marks to be the fuser, I have had the same problem, tried cleaning the charge roller did not resolve, even though it looked perfectly clean and fine. I changed it out anyway and it resolved it
