fs4200 and P3060DN image problem
  • alangraph
    • Feb 2011
    • 14
    [CQ] fs4200 and P3060DN image problem
    Im having a serious problem with my FS4200 and P3060DN, both show the same exact problem. After print serveral pages some time after 1000 other times after 200 the image begin to fade to almost desapear in some areas of the print. Then it returns, like there is no toner or transfer. I have check the developer unit for toner and is loaded. Some times entire white pages come out. I don't know what can be. Those are some samples of the problem. i am printing in NCR paper. I have already printed 60000 pages without problem and now i got this one. Please Help .
  • Alexsiskm
    • Sep 2018
    • 11
    Re: fs4200 and P3060DN image problem
    What is the thickness in grams of your NCR paper? Is the paper type set correctly in the driver?
    Try printing the same file on plain 80 grams of paper, will this problem recur?
    what is the thickness in grams of your NCR paper? Is the paper type set correctly in the driver?Try printing the same file on plain 80 grams of paper, will this problem recur?
    • lees
      • Apr 2011
      • 95
      Replace the developer clutch.
      • Ropariva
        • 654
        Sounds like dev clutch. Genuine toner?
        • alangraph
          • Feb 2011
          • 14
          Thanks, for your input. I am usign generic toner, not the original. It seems that the developing unit is wearing out faster than expected. I change it and the problem seems to be fixed.
          the NCR paper is 50gsm, i am using as light paper in the config.
          I have a new problem some tonner is beging to build on the drum, is hard fixed i have to remove it away with my nail as it too hard for the cleaning blade to remove it. Any ideas?
          When the paper comes out of the fuser there is a lot of steam, im not sure if that steam is causing the toner to fuse a little on the drum surface.
          Any help would be preciated.
          • mita
            • Sep 2010
            • 87
            There are a few types of NCR papers out there some work better than others. What you probably have is a two fold problem non-genuine toner and chemical from the NCR paper
            • Ropariva
              • 654
              • Geo
                • 662
                What "Ropariva" said..
