Kyocera Taskalfa 3500i Print too light
  • pgrom
    • Apr 2016
    • 10
    I have a problem with Kyocera Taskalfa, it prints to light. I replaced the developer, drum, the contacts are clean , the machine not covered with toner. The image on the drum is good but the printout is too light. The copier has printed 100k
    Please Help
  • copiertec
    • Jan 2016
    • 2211
    Re: Kyocera Taskalfa 3500i Print too light
    Have you gone though all of the setup procedures when changing the drum and developer?
    • dalewb74
      • Feb 2018
      • 1155
      sounds like time to take care of the optics.
      • pgrom
        • Apr 2016
        • 10
        yes
        the image on the drum is good when you cut the paper
        • Happy Copier
          • Mar 2019
          • 49
          [ATTACH=CONFIG]43221[/ATTACH]
          Please Help
          Well I am very interested in the solution to this one.
          Sent from my SM-G930V using Tapatalk
          • richs
            • Nov 2008
            • 265
            Looks like you have a transfer problem.
            • JR2ALTA
              • Feb 2010
              • 2033
              I dont know how you can tell the image on the drum is good..it's possible but the drum is basically black.
              I'd say transfer roller or HV board.
              • pgrom
                • Apr 2016
                • 10
                it is a black copy
                This is a drum image while making a copy
                • copiertec
                  • Jan 2016
                  • 2211
                  Agreed, with above. Have you checked the connector on the transfer roller unit? I have seen where it is not seated properly and causes this issue. Where the prints light prior to drum and developer change?
                  • Happy Copier
                    • Mar 2019
                    • 49
                    Were these done in service mode?
                    • pgrom
                      • Apr 2016
                      • 10
                      These are the prints after replacing the drum and de developer and initialization with ServiceManual
                      • Happy Copier
                        • Mar 2019
                        • 49
                        [ATTACH=CONFIG]43224[/ATTACH][ATTACH=CONFIG]43225[/ATTACH]
                        Were they new developer and drum?
                        • pgrom
                          • Apr 2016
                          • 10
                          Yes
                          • Happy Copier
                            • Mar 2019
                            • 49
                            Yes
                            The guy I trust most of the time seems to think you've got a transfer issue.
                            • ntbann
                              • Jan 2012
                              • 628
                              If it is a transfer problem you should be able to do an e-stop and see if there is a good image on the drum.
