Kyocera 300i how to install scanner
  • kashif
    • Apr 2013
    • 45
    i have kyocera talskalfa 300i, i installed printer driver and work properly but the scanner is not working, can someone tell how to install and what is exectly driver for taskalfa 300i
  • JPazy
    • Jul 2019
    • 30
    Re: Kyocera 300i how to install scanner
    Typically Scanning on a 300i is set up using SMB scan. Kyocera has a TWAIN driver for scanning as well on their site.
    • Ropariva
      • 653
      Download Centre
      That should assist with your scanning set up. Works reasonably well. Go to the utilities tab.
      • Reed
        • Feb 2011
        • 259
        You really don't need a driver for it. Unless you install a twain driver. Why don't you just set up scan to email? But if you want Scan to PC .. With all the changes windows has made with the SMB protocol, the best way now is to install a small ftp server file and set it up that way. It will only take a few minutes.
        • dalewb74
          • Feb 2018
          • 1125
          when i worked on kyoceras a few years back i always used filezilla server to setup scan to pc. only issue i ever really had was whenever a customer would close it out. once it was opened again and running in the background it worked well. filezilla works well for those models and newer. the smb scan utilities worked for the older machines.
          • Xer0615
            • Jan 2019
            • 48
            If you're unfamiliar with the process of configuring SMB or email scanning, it's often times easier just to install the Kyocera Print App from the windows ten store. It works in instances where SMB no longer does (thanks to M$ killing SMBv1 support) and the only downside is that you have to hit the "scan" button on the computer itself after placing the originals in the feeder/on the glass, so there's a bit of extra walking
