Kyocera copier doesn't recognize paper in cassettes.
  • BabblingXombie
    • Jun 2015
    • 32
    Any help would be great.
    it doesn't recognize paper in cassettes
    wont print even a status report
    • 30294
    Re: Kyocera copier doesn't recognize paper in cassettes.
    What paper size does it show on the panel?
    • BabblingXombie
      • Jun 2015
      • 32
      it doesn't say and wont let me select paper size
        • 23009
        Maybe it would help to know what model you're working on?
        Are the guides touching the sides of the paper?
        Can you access the Paper Settings from the System Menu?
        Come On! We're going to need more than that! =^..^=
        • Santander
          • May 2009
          • 768
          It would help to know the model of the copier you are working on. Does the display say the paper cassettes are empty or you just cannot print/copy from them? Have you checked to make sure that paper has not gotten behind the cassette preventing the machine from detecting the paper [very common]?
          • BabblingXombie
            • Jun 2015
            • 32
            it says cassettes are empty.
            They are full of paper
            • JR2ALTA
              • Feb 2010
              • 2033
              I don't think the model matters.
              I want pictures
              • copier tech
                • 8172
                I want pictures
                Of course it matters what model!?
                • BabblingXombie
                  • Jun 2015
                  • 32
                  I'm going back monday. Ill get pictures and model number for you guys.
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    Normally yes but not with this issue. It's kinda like "i have lines through the doc feeder". And you're like "what model?"
                    I'd like to see the message on the screen
                      • 30294
                      Sim 906 execute
                      • tsbservice
                        Field tech
                        • 8020
                        Yep, it doesn't matter what are answers in this case.
                        C'mon Zombie you are not member of this Forum from yesterday.
                        It's superficial at least and I'm very soft with wordings, to post question like this.
                        You wasted valuable time of many great members(not including me) here to read and answer such a incomplete thread.
                        • copier tech
                          • 8172
                          Lines when scanning yes irrelevant what moel.
                          But with this issue paper lift etc is different depending on what model! he could have a small desktop or production model.
                          • Dougie179
                            • Apr 2019
                            • 12
                            Check behind the trays and see if there is paper smashed into all the sensors.
                            • mita
                              • Sep 2010
                              • 87
                              If it is a small mfp/printer the switches on the left side for paper size will cause this issue. But I would just be guessing without the model.
