Taskalfa 6052ci - disabled duplex
  • kuby
    • Oct 2007
    • 1400
    I have a TA 6052ci that constantly has a disabled duplex function. No big problem to reset the disabled function ( SM 906 ) but wondering if anyone has had this problem before and a fix. Already has the latest firmware and reloaded the firmware. Still happens.
  • darry1322
    • Oct 2010
    • 817
    Re: Taskalfa 6052ci - disabled duplex
    Just for clarification, disabled for the ADF or disabled for the Engine?
    I had an adf disabled for 2-sided yesterday with CIS codes about every month or so. I haven't investigated further yet.
    • Dougie179
      • Apr 2019
      • 12
      Any "C" codes associated with this disabling ?
      • kuby
        • Oct 2007
        • 1400
        When rebooted after 906 reset, it finally came up with a C3210: CIS lamp problem. Had to reboot two times to get that to go away. Guess it has a lamp problem?
          • 23007
          The CIS lamp is part of the CIS unit. We saw a lot of C3210 codes on Saturns. The most common cause was a failure of the CIS cooling fan, allowing the CIS to overheat. Were it me, I think I would change out the CIS cooling fan(s), ultimately hoping that the CIS is not irretrievably damaged by overheating. Then if it does return, I would change the CIS sensor. =^..^=
          • kuby
            • Oct 2007
            • 1400
            Thanks I will try that..
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1884
              As long as the white roller is clean. It uses it for white reference, and will assume it's not lighting bright enough, if that roller is dirty.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • Geo
                • 662
                Had a similar issue that started several months after install. After resetting the code the copier would work for a couple of days to several weeks before coding out . Yes, I tried all the suggestions , but the final fix was replacing the CIS assembly.
                Cheers
                • bush_tech
                  • Jul 2018
                  • 51
                  I've had this a fair few times
                  • jmaister
                    certified scrub
                    • Aug 2010
                    • 755
                    on the older model... Saturns I think it was. duplex on DP disabled is due to it being too hot, not enough ventilation.
                    Havent done any kyocera lately, but I dont think they have change the fundamental design on the accessories.
                    just a thought.
                    Idling colour developers are not healthy developers.
                    • kuby
                      • Oct 2007
                      • 1400
                      Replaced the 'white' roller and so far so good. Upon inspection it appears to be a black roller with a white coating - dumb.
