CS 3050 not adding toner
  • Boba Fett
    We have a 3050 that will not consistently add toner. We go out look at it get it to work and then half way though the day it craps out. We've done a PM and replaced the dimms on the machine. I have read other forums that say there are brackets out of place. We can not seem to see anything that is out of place. If any one has come across this problem any help would be appreciated.
  • Jimbo1
    • Mar 2008
    • 845
    Can you go into the service mode and turn the solenoid for toner feed on and off?
    You will know because it makes that distinctive clicking sound you here when it is toning up.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
      • 23010
      You can get this effect if your customer installs Type (A) toner for a Falcon II instead of the TK-719 for a Falcon III. The only difference is the drive coupler, which will not mate with the other type, or Copystar to Kyocera, or vice versa. =^..^=
      • aodtech
        • 194
        Does the machine say "Image Cycle" constantly and then go "Add Toner"? If you hear that frequent clicking sound (solenoid), then you might want to check the drive belt (horizontal) on the back lower right part of the machine. I had a 2530 that stripped off part of the teeth on the belt and that caused the gears not to rotate the toner feed clutch.
        • Boba Fett
          It's the right toner and it's Kyocera toner.
          Now it does what aodtech said. No one has mentioned that though. I'll check that out and see what I come up with.
            • 23010
            I think that you may have missed my point. Kyocera toner (KM-3050) will not work in a Copystar (CS-3050).
            Both are made by Kyocera, and the couplers are different. =^..^=
            • Boba Fett
              No they have another 3050 right by it that we've tried swaping the toners so I know that's not it.
              • randula7
                • 73
                Are you check DV unit well thear is some little pad to clean toner sensor its rotate and clean dv toner sensor if it lose never add toner.
                • ozan23
                  • 7
                  look tu toner container back in 3050 (same 3035)(to put out toner container) toner celenoid gear corrupt or difficulty
                  • moussmouss
                    Connecting gears on toner box and in machine are not engaging
                    • moussmouss
                      toner box gear and machine gear are not engaging,gears making contact on outer edge and not engaging together,nail clipper will trim excess flares on edges.
                      • leroyal
                        Expert on The Obsolete
                        • Sep 2007
                        • 156
                        Fee, Fi, Fo, Fum...I smell non-Kyocera toner cartridges-um
                        I know what I know better than anyone else knows what I know.
                        • Jules Winfield
                          • Jul 2009
                          • 821
                          Yeah, it's either a mismatched coupler or stripped toner drive belt...
                          But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
                          • Craigdumass
                            • Jun 2009
                            • 61
                            First of all, what kind of volume is the customer running along with what percentage of fill are they doing. If it does indeed go into Image cycle, I have had two of the following post from above and either one could be dead on. The Coupler one and the other with the teeth on the belt.
                            • Warstg_20
                              • Sep 2009
                              • 72
                              I agree with this post i encounter it in field
                              Maybe you are using not genuine toner
