F041 code
  • nathicana
    • Aug 2008
    • 330
    F041 code
    This 5501 machine has an F041 code, communication between main pwb and ISC pwb. Tried main pwb, Isc pwb, hard drive, CCD
    Can enter maintenance mode and see that in sim 019 there is no scanner boot or scanner firmware. Attempted combined firmware and error occurred on DP.
    Tried disconnecting DP and replacing DP, no difference. Anything scanner related appears to be dead.
    Going to check CN7 power source board to verify power going to ISC pwb
    • 23006
    Re: F041 code
    What about the connectors and wire harness? =^..^=
    • nathicana
      • Aug 2008
      • 330
      Re: F041 code
      I replaced the SATA wire and the gray wires that go between the ISC pwb and main board with ones from a recently working machine, no change.
      24v was present on the ISC pwb.
      I am in the process of replacing the entire scanner section with one from a used machine.
      • Santander
        • May 2009
        • 768
        Re: F041 code
        I suspect the unit does not even know that it has a scanner due to a bad connection from the ISC to the main board. Make sure all the connectors between the two are seated fully and especially the flex cable. I have seen where even if you are careful, one of the contacts is de-laminated from the flex cable and bent backwards on insertion and there is no contact. If you had a DP problem you would be getting a different code. Hope this helps.
        • nathicana
          • Aug 2008
          • 330
          Re: F041 code
          ISC board YC3 and YC4 are the only connectors that go to the main board. One is a red SATA wire the other a short 8 wire harness. I replaced both of these and the two boards have been changed also. The flat cables go from the ISC board into the scanner, not to the main board. I am replacing all that anyway though. There are other flat cables going from the main board to other places. Thanks
          • nathicana
            • Aug 2008
            • 330
            Re: F041 code
            I replaced the scanner section and the machine began working. I agree that there may have been a bad connection somewhere.
            Good thing we had a machine in our junk room to take this from.
            Thanks for the replies
            • Santander
              • May 2009
              • 768
              Re: F041 code
              Thank you for letting us know what resolved your problem. Glad you got it going.
                • 23006
                Re: F041 code
                Having a parts donor sure makes diagnosis easier.
                Congratulations on your success! =^..^=
                • KYO_OEM
                  • Aug 2011
                  • 711
                  Re: F041 code
                  Have had similar case a few years ago.
                  4 ISC pwbs needed to find the reason.
                  Finally i tried CCD pwb, lamp driver pwb and brand new isc pwb
                  After mounting from old isc pwb, F041 comes back.
                  Each new mounted ISC pwb would destroyed from LED lamp driver pwb.
                  • nathicana
                    • Aug 2008
                    • 330
                    Re: F041 code
                    Thanks, I was wondering what component may have caused this if it wasn't a connector problem. I had tried the ISC pwb and the CCD so the lamp circuit may have been the culprit.
