Hi Folks - I'm having an issue with a few of these machines showing up "Error Occurred at Cassette" - I have come across it before and as resolving the issue is normally just a case of opening and closing the cassette most users have just dealt with it.
We have a few high volume machines however that I will need to get resolved. They print A3 booklets so cassettes are normally filled with ream of A3 - it's 75g so sits below what I would consider to be overfilled - when user sends the print job the machine will pick up a few pages and then display this error - if they open and close the cassette after about 10 pages it will throw up the error again. If they open and close the cassette a second time it will tend to run through the rest of the ream without the error occurring again.
Is this likely to be a weak lift motor or is there something else that causes this to happen? I think the issue seems to happen in pairs ie - on one machine cassette 1&2 have the error and on another it could be 3&4 but I could be wrong about this or or it could just be a coincidence. I have replicated the error myself quite easily so ruling out the user overfilling/not setting paper in right/fanning the paper/making the whole thing up
While I was out at it I tried the following:
swapped the cassette inserts
replaced feed tyres
swapped the complete feed assy
taken off auto paper size detect
Any advice would be greatly appreciated
replaced feed tyres
