5551ci - Error Occurred at Cassette
  • autopilot
    • May 2011
    • 68
    Hi Folks - I'm having an issue with a few of these machines showing up "Error Occurred at Cassette" - I have come across it before and as resolving the issue is normally just a case of opening and closing the cassette most users have just dealt with it.
    We have a few high volume machines however that I will need to get resolved. They print A3 booklets so cassettes are normally filled with ream of A3 - it's 75g so sits below what I would consider to be overfilled - when user sends the print job the machine will pick up a few pages and then display this error - if they open and close the cassette after about 10 pages it will throw up the error again. If they open and close the cassette a second time it will tend to run through the rest of the ream without the error occurring again.
    Is this likely to be a weak lift motor or is there something else that causes this to happen? I think the issue seems to happen in pairs ie - on one machine cassette 1&2 have the error and on another it could be 3&4 but I could be wrong about this or or it could just be a coincidence. I have replicated the error myself quite easily so ruling out the user overfilling/not setting paper in right/fanning the paper/making the whole thing up
    While I was out at it I tried the following:
    swapped the cassette inserts
    replaced feed tyres
    swapped the complete feed assy
    taken off auto paper size detect
    Any advice would be greatly appreciated
    • 23010
    Re: 5551ci - Error Occurred at Cassette
    On the AplhardII series we've seen failing vertical path motor and/or seizing vertical path bushings. As they age, they seem to dump ever increasing amounts of toner into the vertical path. The toner fuses nicely to warm things like motors. That's where I would start. =^..^=
    • lees
      • Apr 2011
      • 95
      I had this same issue on a 8002i that turned out to be the engine board. I was not able to clear the error at all. It always said there was an error in cassette 1. If you left cassette 1 out and powered machine on, it would go to cassette 2. I left both cassettes out of the machine and turned it on and the lift motors for trays 1 and 2 turned continuously. I could push up on the feed roller for one of the trays and the corresponding lift motor would stop, but still error out. After replacing the engine board the issue went away. Hope this will help someone with a similar issue.
      • JPazy
        • Jul 2019
        • 30
        i've seen this a lot on the 500ci series where the lift motor needs replacement. be careful when taking the machine out of auto paper size mode, if they have a fax board installed it will have problems printing received faxes.
        • Scottb
          • Apr 2013
          • 308
          I would try 302KV44041 clutch...4 ea for the drive section and 1 ea for the vertical path roller behind said section just because you are there and its a pain to have to replace later when you could have done it at the same time
          • callservice
            • Sep 2011
            • 26
            Check and replace the Photo sensors behind the Cassettes. May be its out of position .
            When the copies are running the paper lift plate position measured by this sensors.
            • CoreyAbels
              • Dec 2014
              • 92
              Good afternoon
              I am having the same type of issue with 2 different "1 Series" machines as well. I have a 5501i as well as a 3051ci machine experiencing the "Error Occurred at Cassette" message. This same theory applies to those devices as well, correct? I know there are some minor differences between the machines and I can never seem to replicated the issue. I have replaced the Feed Drive Clutches and Feed Rollers on both machines, and additionally, replaced the Feed Assemblies on the 3051ci. Thanks for any insight you can provide!
                Originally posted by CoreyAbels
                Good afternoon
                since the last reply ( with no resolve ) was a year ago...
                and you have 2 different problems...
                may I suggest you post a NEW thread for each machine....
                listing:
                What parts are replaced.
                what the total pages printed vs PM parts
                error codes listed..
                any pertinent info
                • J-Tin
                  • May 2020
                  • 12
                  Lift motor(s)
