TASKALFA 5500i
  • Gab
    • Aug 2015
    • 671
    TASKALFA 5500i
    It is a second hand copier. I cleaned it and tested it and machine was ok.
    I had this machine for few days in my car (to sell it) but finally i stored it in warehouse (waitting for customer call to deliver it).
    Finally i tested it before i deliver it to customer. Now there is a solid repeated dot diameter 2 mm every 3 cm interval.
    This dot is not caused from drum because in this case the distance between dots will be longer. Any idea where to clean?
  • copiertec
    • Jan 2016
    • 2211
    Re: TASKALFA 5500i
    Charge Roller or developing unit.
      • 23009
      Re: TASKALFA 5500i
      If it's 37.5mm it's one or more of the primary charge rollers, based on the color of the dot.
      The early versions of the charge roller that had the brush cleaners tolerated cleaning with water or glass cleaner fairly well. The new version of the primary charge rollers with the helical foam cleaner do NOT tolerate cleaning. Instead of getting the waterspot like you might get on the old roller, you get a nice round dot instead.
      So if you have new style primary charge rollers cleaning is out of the question. Only replace.
      Kyocera will probably get the hang of making good primary charge rollers ... but not in my lifetime. =^..^=
      • Gab
        • Aug 2015
        • 671
        Re: TASKALFA 5500i
        dot color is solid black
          • 23009
          Re: TASKALFA 5500i
          So what conclusion would you come to? =^..^=
            Re: TASKALFA 5500i
            +1 on this and Yes it is drum assmy related.
            • copiertec
              • Jan 2016
              • 2211
              Re: TASKALFA 5500i
              Ditto Kyo making a good charge roller. I have been cleaning the new style with slightly damp cloth and it has been working out so far. We have a client running about 80k a month on a 8001i and I am there once a month for either cleaning the charge roller or replacing an entire fuser kit because the damn lift motor keeps going bad. We must have a handful of fusers we have sent back because of faulty lift motors.
              • copier tech
                • 8174
                Re: TASKALFA 5500i
                Swap the black charge roller with say the yellow then do another test print if the dot changes to yellow replace the change roller with new.
                Personally i'd replace all 4 while you're at it.
                • darry1322
                  • Oct 2010
                  • 817
                  Re: TASKALFA 5500i
                  5500i....only one charge roller.
                  • Tonerkiller
                    • Oct 2012
                    • 668
                    Re: TASKALFA 5500i
                    I only have one question. What kind of a car do you Have?
                    • jper34
                      • Sep 2011
                      • 225
                      Re: TASKALFA 5500i
                      It sounds to me like a charge roller spot..you may be able to clean it, most times, I've replaced the charge rolle..good luck
