Kyocera 3212i Sporatic Lines & Blank Prints
  • Happy Copier
    • Mar 2019
    • 49
    [CQ] Kyocera 3212i Sporatic Lines & Blank Prints
    Customer says copier will just start printing blanks, turn machine off and back on and everything is back to normal. The attached picture happens every once in a while also. The machine only has 12k on it. Thanks for any help!
    Sent from my SM-G930V using Tapatalk
  • Happy Copier
    • Mar 2019
    • 49
    Re: Kyocera 3212i Sporatic Lines & Blank Prints
    My buddy thinks it could be a laser issue because on that pic I sent the vertical lines stop when it's time to print actual image, and then continue again after it prints image.
    • sparkycivic
      • Apr 2017
      • 348
      change the charge roller, or entire drum kit - it's arcing.
      • cmpelser
        • Jan 2008
        • 173
        I also have this problem.
        Was there a definite solution?
        • kyotechnz
          • Mar 2019
          • 145
          I also say replace the drum unit.
          Had a machine doing the same recently and it was the drum unit causing the problem.
          • KYO_OEM
            • Aug 2011
            • 721
            When i checked the pic, i could see that stripes also located in the margin areas.
            Looking like stripes against running direction, no laser, no dv problem. main charge problem because of stucking drum drive.
            I would start with new dk unit and check from drum drive.
