F000
  • Momiowilove
    • Sep 2019
    • 63
    [CQ] F000
    Good day i have a kyocera 6525 have an indication of F000. Thry say its firmware problem or the PWB. Can you give me another way to solve this problem thank you
    Sent from my RNE-L22 using Tapatalk
    Re: F000
    have you TRIED the suggested fix?
    what else have you done?
    • Momiowilove
      • Sep 2019
      • 63
      Re: F000
      No I didn't try it yet. For the problem they told me the firware problem. Is it possible that the firware is need to update?
        Re: F000
        yes
        • Alle
          • Mar 2015
          • 5
          Re: F000
          It has bulletin to do, you need to follow that. but run U024, because in 2012 this issue was common causing by firmware or DIMM, but today mostly just HDD
          Allen
          • avio2
            • Jul 2010
            • 150
            Re: F000
            hello,i have one UTAX 256i whit a strange error
            the machine work all correctly , scan,print, copy, read to usb ecc.ecc but in web page not have section for set ONE TOUCH , only address book
            when i attempt to upgrade fw whit usb pen drive this not work, go to F000
            usb pen drive ok(testedwhit another mfp)read to usb ok(check a document)
            i have rea last bt utax but only suggest is for f245 whit reset fw but i have fear to block all
            any idea?
              • 22989
              Re: F000
              Printing web pages can be problematic for Kyoceras. When possible, select "View as PDF" or "Printer Friendly Page". In some webpages you'll have the option to "Download as PDF". You'll be able to print the downloaded PDF document.
              The way I understand it, the links built into the webpage closely resemble PreScribe commands (the native language of Kyocera printers), confusing the printer. The PDF or Printer Friendly Page will have those links removed.
                Re: F000
                That clears up some questions I've had. Thanks.
                • avio2
                  • Jul 2010
                  • 150
                  Re: F000
                  [QUOTE=blackcat4866;2080753]
                    • 22989
                    Re: F000
                    So your machine works? You just cannot update the firmware? =^..^=
                    • avio2
                      • Jul 2010
                      • 150
                      Re: F000
                      [QUOTE=blackcat4866;2080998]Quindi la tua macchina funziona? Non riesci ad aggiornare il firmware? =^..^=[/CITAZIONE]
                      yesazzo:
                      • avio2
                        • Jul 2010
                        • 150
                        Re: F000
                        i think this 3d are in bad forum section ,can you move to the right section?
