Kyocera 6025
  • Momiowilove
    • Sep 2019
    • 63
    [CQ] Kyocera 6025
    Hello to all i have system error problem in kyocera 6025 error code 3200.
    Sent from my RNE-L22 using Tapatalk
    Re: Kyocera 6025
    Originally posted by Momiowilove
    Hello to all i have system error problem in kyocera 6025 error code 3200. Sent from my RNE-L22 using Tapatalk
    10 sec Google search
    Error Codes > Kyocera > FS6025MFP > Code 3200
      • 30294
      Re: Kyocera 6025
      H AHAHAHAHA using bias Google
      Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
        • 23009
        Re: Kyocera 6025
        Matsuri are known for Main Board failures, specifically causing C3200 errors and black copies and scans. =^..^=
        • JR2ALTA
          • Feb 2010
          • 2033
          Re: Kyocera 6025
          Could this be a simple scanner lock engaged? Or filty optics/white reference?
