Kyo FS-6525 Fuser interesting problem
  • DougMoney
    • Feb 2017
    • 70
    I have a customers FS-6525 that started occasional jamming then kept getting worse. When I was called it was down to every 8-10 pages. Finally every page. I swapped the fuser uniit out and problem solved. My curiosity said check the fuser. I can find nothing wrong with the fuser. Good rollers all turning, pickers look fine. The jammed copies had the corner folded but I can't find what was causing it. I know I could just throw the fuser away, but I like to know what caused the issue. Anybody know of anything odd on these? Thanks.
    Re: Kyo FS-6525 Fuser interesting problem
    well clearly something is causing the dog ear..
    do a stop test to find where it is getting the 'ear'
    check inlet plate for toner build up
    you never mentioned total pages on fuser and it's rated life span.
    • jewen25
      • Mar 2009
      • 197
      Chk the bushing maybe getting loss
      ERROR HELP ME AND HELP YOU
        • 23006
        Jam code?
