Kyocera M3540idn "no paper in cassette" error
  • StratManDan
    • Nov 2018
    • 96
    Hi Guys,
    I have a Kyocera M3540idn in the field that is again showing "no paper in cassette" error. On a previous visit to the site, the user had not turned the size indicator on the cassette to the proper setting, according to what size paper was placed in the cassette. There was Letter size in the cassette, so I changed the "roller wheel" size indicator to LTR, which solved the issue.
    Now the printer is again showing "no paper in cassette" error. Is there something I'm missing? Any suggestions would be appreciated. Thank you.
  • dalewb74
    • Feb 2018
    • 1153
    Re: Kyocera M3540idn "no paper in cassette" error
    are there 2 cassettes or just the 1? have you tried just replacing the cassette? that was always just a quick test i used to do was switch the tray with the second one or another tray.
    • StratManDan
      • Nov 2018
      • 96
      There is only one cassette. That was my next plan of attack. I'm taking a spare printer, of the same model, with me to the site.
      Thanks for responding!
        • 23007
        Does the paper lift or just "clunk, clunk, clunk"? =^..^=
        • Luther
          • May 2006
          • 682
          Take the tray out and look in the machine...you will find the add paper arm is out of position, its white and about 3 inches long. it is very common, it is attached to the duplex plate in the cassette opening
