Kyocera Toner
  • anthony123
    • 62
    Kyocera Toner
    Hello, Has anyone found a generic toner for the M3040idn and 2535idn that does not cause problems?? I tried Precision Roller and it caused the drums to fail early, way early. How about Katun anbody??
    Thanks Ant
  • patrickjlc
    • Feb 2015
    • 225
    Re: Kyocera Toner
    Thanks Ant
    I use the katun and have no problems, use them on m3040idn, 3550idn, fs4200, etc. On the 3550 and 4200 i get close to 30k prints.
    Sent from my SM-G930V using Tapatalk
    • ntbann
      • Jan 2012
      • 628
      Re: Kyocera Toner
      Good luck. Kyo's do not like generic toners. No way no how!
      • Leebs14
        • Feb 2014
        • 457
        Re: Kyocera Toner
        Hi Anthony, not sure where you are based, here in the UK I use a generic toner from a company called THS from Germany, it works really well.
        Thanks Ant
        • sanvicente
          • Aug 2011
          • 31
          Re: Kyocera Toner
          Integral toner (german manufactured) works fine. Used in several machines for more than a year in 3-5k prints per month with out issues. Thats tk3102.
          In m2040dn (tk1175) we note a lighter black on solids. No costumer complains yet but we noted that. Recently start using CET toner who works very well for us in 1135 and 2035 (1142-1147).
          • allan
            RTFM!!
            • 5462
            Re: Kyocera Toner
            Yea THS toners works great. Problem is it became to expensive for us to import...
            The bizhub machines loved that stuff. One some models i would argue its somehow better than original dare i say.
            Whatever
            • dalewb74
              • Feb 2018
              • 1157
              Re: Kyocera Toner
              i agree with the other post. kyocera doesn't play well with generic...
                • 23009
                Re: Kyocera Toner
                This is true of Canon monocomponent as well. I've had poor results from all generic monocomponent toner.
