Kyocera KM-5035 does not wake up from power save mode
  • AlexRust
    • Apr 2014
    • 41
    Kyocera KM-5035 does not wake up from power save mode. It show blank screen but self check was done. Disconnect and reconnect power at wall plug brings copier to normal operation. What should I replace Engine board or Power board or both or something else? Thanks in advance for all your help...
  • Ropariva
    • 671
    • Tom
      • 344
      Re: Kyocera KM-5035 does not wake up from power save mode
      Originally posted by Ropariva
      Where’s your firmware at? I’ve had a few 4053s recently with the same issue. Firmware has sorted it.
      Does that old machine (5035) even take a firmware update? I can't remember. They were some darn good machines in their day, but I never hooked them up for scanning, only print and copy. Didn't much like that DP though. Being that it's 15 years old it might be a good time to upgrade it.
      • JR2ALTA
        • Feb 2010
        • 2033
        If I were a 16 year old copier I wouldn't want to wake up either.
          • 23007
          You might try removing the fax option. They've been known to cause bizarre issues. =^..^=
