kyocera taskalfa 300ci WELCOME message
  • wcanonw
    • Aug 2014
    • 404
    hello I have a kyocera taskalfa 300ci when turning on the panel shows a message "WELCOME"Check the main card and clean the ram memory, I don't have the fimware
  • M.Lerche
    • Nov 2019
    • 6
    Re: kyocera taskalfa 300ci WELCOME message
    I had the same problem.
    Motherboard changed ,complete keypad changed ,RAM memory changed ,hard disk changed,
    all without success
    Maybe the firmware memory itself is defective.
    we have disposed of the machine the costs are too high for further experiments
    • copier tech
      • 8161
      all without success
      Its good practice to update the firmware first before replacing board etc.
      • M.Lerche
        • Nov 2019
        • 6
        I tried firmware first.
        Maintenance mode was also no longer possible even with an open door
        all options have been separated
        all without success
        • wcanonw
          • Aug 2014
          • 404
          hello master has the firmware ????
          • wcanonw
            • Aug 2014
            • 404
            all without success
            My problem is that I do not have the firmware I have searched the same website of kyocera and without success of obtaining the blessed firmware
            • martinar
              • Mar 2017
              • 27
              Try the code dimm (or simm?) on the main board
              • KYO_OEM
                • Aug 2011
                • 718
                No way out without firmware!
                Inside from firmware dimm, there is also startup BIOS located.
                If you mount new firmware dimm, you also must upgrade to compatible versions to engine FW and MMI FW.
                Did you refit the dimm to the upper slot? It`s named "Code" slot.
                Don`t mix with fax dimm......(if fax installed)
                • wcanonw
                  • Aug 2014
                  • 404
                  hello a favor do you have the firmware?
                  I need the firmware to see if the fault is due to the firmware
                  • KYO_OEM
                    • Aug 2011
                    • 718
                    144MB for FW V15.
                    But if still running FW V10 or less you has to run the upgrade twice.
                    1. Upgrade to V10
                    2- Upgrade to V15
                    This means 288MB
                    Not possible to send by Email.
                    FW only won`t help.
                    You also need new Dimm or well working Dimm from other Saturn system (250ci/300ci/400ci/500ci)
                    (If you know how to do, you can exchange the Dimm during upgrade procedure, but if you make a mistake you`ll have 2 broken Dimms)
                    • syahputrarangga
                      • Nov 2019
                      • 3
                      Taskalfa 250ci_300ci_V.13.00
                      Taskalfa 250ci_300ci_FirmwarePack_13.00 - Google Drive
