mystery part between taskalfa 4550ci and PF740; also request suggestions on joining
  • allanc
    • Nov 2019
    • 4
    [Misc] mystery part between taskalfa 4550ci and PF740; also request suggestions on joining
    Long time owner/leasor of about 6 of the taskalfa series.
    Just picked up a working 4550ci for $350 with the finisher and PF740 cassette 3/4.
    Unfortunately, wasn't able to do it wrapped with a liftgate (long drive), and
    separated the top from PF740 to bring it back upright in vehicle.
    Back in the office, managed to crunch the plastic part poking up from the deck
    of the PF740 that the paper feeds through when reassembling (2 of the 4
    people helping didn't speak english). This of course results in jams when feeding from
    cassette 3/4 (rest of copier works fine).
    I've gone through 4550 service manual, parts manual and the PF740 service manual and parts manual.
    That piece doesn't show on many of the diagrams for assembly or pictures.
    After first thinking it was the vertical conveyor or primary feeder, I think now the part
    number is 303NF94010 middle roller unit.
    1) can someone confirm this is the right part. Any good sources for parts...
    2) what is the best way to mate these 2? I'm thinking maybe put some
    spacers on top, align, and then gradually remove until the copier is on top.
    Is it possible to fit that part in after assembling by removing some of the vertical
    conveyor assembly stuff?
    thanks,
    allan
    • 22801
    Re: mystery part between taskalfa 4550ci and PF740; also request suggestions on join
    conveyor assembly stuff? thanks, allan
    a picture of the part might be really helpful
    • Hose1cook
      Defective Technician
      • Jun 2008
      • 80
      thanks,
      allan
      1) That is the right part
      2) It's installed after the machine is placed on the PF-740-see attached
      PF-740MLIIR4.pdf
      • copier tech
        • 8095
        [ATTACH]44055[/ATTACH]
        A photo of the broken part(s) would be more useful.
        • allanc
          • Nov 2019
          • 4
          I first thought that was it...part on page 6, the intermediate conveying unit.
          but it's not. inside and lower than that.
          just a plastic guide (crunched) with rod & 4 or 5 rollers. can THAT be removed after it is assembled?
          was hoping to avoid getting 4 people to pickup again for photo.
          but I attached image. the image doesn't show the part, but it would
          be where I drew red circle.
          I'll shim it up tomorrow. need to anyway to do the replacement
            • 22917
            Agreed. that part is fitted AFTER the MFP is resting on the PF unit. If you fit it before, it will become broken again. See item D, page 8 of the installation guide, attached to TBS's post. =^..^=
            • allanc
              • Nov 2019
              • 4
              thanks, lots of good info and help here. I'll probably be picking your
              brains in future since I'm maintaining this one myself.
              My mistake was thinking the intermediate conveying unit on pg 6 of
              the PF740 manual was different from the middle roller unit.
              With it up, it's obvious I should have joined, removed the upper door,
              and then installed.
              Here is pic for archives.
