FS-2100 PRINT QUALITY
  • tuey
    • Apr 2014
    • 120
    have one of these that i had used as a loaner and at it's last stop-a tax preparer- it was randomly printing really light to completely blank on certain lines on printed pages, some are perfect. hooked it up in my office and it does the same thing. is there any known issue like this with these? i do believe that the firmware is up to date, i think i updated it when it was at the accountants office. all oem supplies. thanks--tuey
    • 23009
    Re: FS-2100 PRINT QUALITY
    After generic toner, I'd say primary charge roller and/or drum unit. These machines tend towards random light bands crossfeed well before the PM kit comes around. =^..^=
    • CWP
      • Jun 2013
      • 168
      That printer series has a developing unit clutch that I have seen slip many times. Just replace it and don't bother trying to clean it. Make sure you get the correct one as the registration clutch is right there in the same pack. I think the developer clutch is the on towards the back of the machine.
      • tuey
        • Apr 2014
        • 120
        update, finally got to spend some time with these printers. it's not that its missing random lines - they are not able to reproduce some lines and small highlights on the invoices. switched drum/dev units between the 2 machines - no change. was switching parts and machines at customer location and tried all options, still just a bit faded.so i suspect optics and removed -looked clean- cleaned anyway. did this at shop so i have not been able to test with customer documents, next week. all oem toner drums - 1 machine has 600 prints the other 16k. is the print quality known to be light on this series? thanks-- tuey
          • 23009
          Originally posted by tuey
          ... Is the print quality known to be light on this series? thanks-- tuey
          No.
          In this order:
          Generic toner
          Charge roller
          Drum unit
          As the components age (time, not necessarily by print count), you tend to see more banding crossfeed. If your customer bought this machine for 11% halftones they'll probably be disappointed.
          • tuey
            • Apr 2014
            • 120
            both oem toners so i might just have to replace a roller and drum to see. i forgot to ask them about their 11% halftone use when i sold it. not a fan of the kyo printers, almost all the models i've sold have had design flaws of some sort. i personally prefer the hp brand to these- less problems more profit-- the kinda things that keep me doing this for a living/hobby. thanks for the help--tuey
            • tuey
              • Apr 2014
              • 120
              other than aftermarket i dont see and primary charge rollers sold, wouldn't that be part of the drum unit? i've found a full maint kit reasonable but if age kills these parts how will i know when the kit was manuafacured, is it marked on box? thanks--tuey
                • 23009
                Results for MC-3100
                Kyocera 302MS93042 (302MS93045) Drum Unit, Genuine (K0259)
                Yes, you can get the primary charge separate, or with the drum unit, or as part of the PM kit. =^..^=
                • tuey
                  • Apr 2014
                  • 120
                  sorry i thought you said primary charge not main charge. yes i saw where the kit had both main charge unit and drum. trying to decide weather to risk the $ of the kit to try and fix this. thank-you-- tuey
                  • tuey
                    • Apr 2014
                    • 120
                    bought the kit , tried both parts one at a time in both machines, no joy. exact same p.q. -- thanks-tuey
                    • spw
                      • Mar 2015
                      • 62
                      Definitely agree with CWP. The clutches go out on these and the whole series up to the MFP models as well. These are the exact symptoms for clutches,
                      • spw
                        • Mar 2015
                        • 62
                        Just realized this thread said 2019 instead of 2020 oh well. hope it worked out
