Background operation panel
  • Froota
    Field service tech.
    • 129
    [Misc] Background operation panel
    Hi,
    Don't know if this question already passed, but is there a possibility to personalize the background image of the operation panel for the Taskalfa series, for example the Taskalfa 2553ci?
    You can choose some pre-defined pictures in the admin portal, but that's it. We would like to put our company logo on it....
    Thx advance for your help!
    Regards,
  • CWP
    • Jun 2013
    • 168
    Re: Background operation panel
    Froota, yes you can do this by creating the image and saving it correctly on a USB drive and installing it on the machine through maintenance mode U224. Basically you create a PNG image file that is 480x800 and save it with the correct name and install it at the machine. Below are the two main screens - Startup is the power on screen and Home Menu is the background wallpaper you see from the home screen; don't make it too busy or the icons will get lost. Most dealers will just put their logo on the startup screen.
    Startup screen
    Length: 480
    Width : 800
    PNG
    Home Menu
    screen
    Length: 480
    Width : 800
    PNG
    • kuby
      • Oct 2007
      • 1431
      I believe that is U224.
      U224 Setting Original Panel Display
      (Message: Install Original Panel Display)
      Description
      Change the image data and the message for the opening screen at the startup and theimage data and for the
      service call screen to specified data.
      Purpose
      This mode is to customize a display as user's preference.
      Setting
      1 Write the image data or the message data to the USB drive.
      2 Insert a USB drive into the USB drive slot.
      3 Turn the power switch on.
      4 Press [Start] key.
      5 Select the item to set.
      6 Select the item to set.
      7 Press [Start] key.
      Install or uninstall start.
      8 [OK] is displayed when complete properly
      Supplement 1: File information
      Items Contents
      Install Install the image data or the message data
      UnInstall Restore the original image data or message data
      Operation item Partial Lock 1 Lock
      Opening Img Startup screen Entire start display
      Call Img Service call screen Graphic display area
      Home Menu Img Home Menu screen Home Menu display area
      Call Msg Top Service call message 1 Message display area (top)
      Call Msg Detail Service call message 2 Message display area (descriptive area)
      Description File name Image size (in
      pixels)
      File format
      Startup screen opening_ext_image.png Length: 480
      Width : 800
      PNG
      Service call screen callwin_ext_image.png Length: 200
      Width : 180
      PNG
      Home Menu
      screen
      menu_background.png Length: 480
      Width : 800
      PNG
      • Froota
        Field service tech.
        • 129
        Thank you guys for the quick respons,
        I'll keep you posted after I tried this out, many thx!
        Froota
        • dalewb74
          • Feb 2018
          • 1167
          fyi i did it the way that was mentioned. and i noticed you said you want to use company logo. just be advised once you had a new one to it, you lose all of the others. then you basically have to create a new one. and the file name and size has to be exact in order to work. whenever i did it i was just testing the process. good luck.
          • dschultz31
            • Aug 2018
            • 36
            Thanks for the advise, I've done this on a 5551ci and pressed the "Uninstall" button in the U224 screen. The original Kyocera home screen came back. I've not tried with our new xx53ci series... something to do tomorrow.
            • Froota
              Field service tech.
              • 129
              Hi,
              I also tried this out, and it works nice, thx for the advice!
              If we need a more standard screen we will just create a full black one or something else, and problem is solved.
              The only pitty thing is that the 8 buttons on the main screen can not be placed at random positions, they are just following the line from the top line to the 2nd line.
              So you can not create a more 'free' space for example on the right side of the screen to place a logo there.
              Regards,
