Background operation panel
  • Froota
    replied
    Re: Background operation panel
    I also tried this out, and it works nice, thx for the advice!
    If we need a more standard screen we will just create a full black one or something else, and problem is solved.
    The only pitty thing is that the 8 buttons on the main screen can not be placed at random positions, they are just following the line from the top line to the 2nd line.
    So you can not create a more 'free' space for example on the right side of the screen to place a logo there.
    Regards,
  • dschultz31
    replied
    Originally posted by dalewb74
    fyi i did it the way that was mentioned. and i noticed you said you want to use company logo. just be advised once you had a new one to it, you lose all of the others. then you basically have to create a new one. and the file name and size has to be exact in order to work. whenever i did it i was just testing the process. good luck.
    Thanks for the advise, I've done this on a 5551ci and pressed the "Uninstall" button in the U224 screen. The original Kyocera home screen came back. I've not tried with our new xx53ci series... something to do tomorrow.
  • dalewb74
    replied
  • Froota
    replied
    Thank you guys for the quick respons,
    I'll keep you posted after I tried this out, many thx!
    Froota
  • kuby
    replied
    I believe that is U224.
    U224 Setting Original Panel Display
    (Message: Install Original Panel Display)
    Description
    Change the image data and the message for the opening screen at the startup and theimage data and for the
    service call screen to specified data.
    Purpose
    This mode is to customize a display as user's preference.
    Setting
    1 Write the image data or the message data to the USB drive.
    2 Insert a USB drive into the USB drive slot.
    3 Turn the power switch on.
    4 Press [Start] key.
    5 Select the item to set.
    6 Select the item to set.
    7 Press [Start] key.
    Install or uninstall start.
    8 [OK] is displayed when complete properly
    Supplement 1: File information
    Items Contents
    Install Install the image data or the message data
    UnInstall Restore the original image data or message data
    Operation item Partial Lock 1 Lock
    Opening Img Startup screen Entire start display
    Call Img Service call screen Graphic display area
    Home Menu Img Home Menu screen Home Menu display area
    Call Msg Top Service call message 1 Message display area (top)
    Call Msg Detail Service call message 2 Message display area (descriptive area)
    Description File name Image size (in
    pixels)
    File format
    Startup screen opening_ext_image.png Length: 480
    Width : 800
    PNG
    Service call screen callwin_ext_image.png Length: 200
    Width : 180
    PNG
    Home Menu
    screen
    menu_background.png Length: 480
    Width : 800
    PNG
  • CWP
    replied
    Froota, yes you can do this by creating the image and saving it correctly on a USB drive and installing it on the machine through maintenance mode U224. Basically you create a PNG image file that is 480x800 and save it with the correct name and install it at the machine. Below are the two main screens - Startup is the power on screen and Home Menu is the background wallpaper you see from the home screen; don't make it too busy or the icons will get lost. Most dealers will just put their logo on the startup screen.
    Startup screen
    Length: 480
    Width : 800
    PNG
    Home Menu
    screen
    Length: 480
    Width : 800
    PNG
  • Froota
    started a topic [Misc] Background operation panel
    Don't know if this question already passed, but is there a possibility to personalize the background image of the operation panel for the Taskalfa series, for example the Taskalfa 2553ci?
    You can choose some pre-defined pictures in the admin portal, but that's it. We would like to put our company logo on it....
    Thx advance for your help!
    Regards,
