255c front door won't stay shut
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Anyone seen this and have a remedy. The flap over the drum/dv units & the upper flap over the top of that seem to lock into position.
    They are pretty springy, but i can't see anything broken/missing/damaged. The cover switch is in the upper center of the door and will run if pushed or taped.
    I've reseated all drum & DV units. Any ideas are appreciated.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • 23009
    Re: 255c front door won't stay shut
    I've done this to myself a couple of times: On the upper section you latch the right but the left isn't quite latched. You can close the door and it closes. After about 20 pages the door pops open all by itself. The vibration is enough. =^..^=
    • tmaged
      • Oct 2008
      • 1890
      I went back & checked eveything closely, but could not get the switch to stay made. I ended up pulling off the whole front gray section. Under that, I found the cover switch had some play. I made a shim to go behind it, to keep the switch pushed forward. I also went ahead & put the new front gray frame cover on, since it's a lot of work to get to. Never had a problem after I got it back together. I'm guessing it was the switch, but not 100% positive.
      Hope that helps !
      -Tony
      www.dtios.com
        • 23009
        Yeah, it's not much fun getting the front apart. Good idea doing the new inner front cover at the same time. =^..^=
        • JVergin
          Service Tech / IT Rep
          • 216
          I've seen this a few times. The door wouldn't physically come open, but it would think the door was open.
          If this problem happens to come back for you, I know there are two different styles of sensor flags for these models. One has rounded corners and the other does not. I've had to swap out this part at a few places due to the problem you're describing. The one without the rounded corners is the one that should be used.
          These are from a B/W model but should be close enough if not identical to illistrate what I'm talking about:
          • buzz
            • Aug 2013
            • 288
            For me, front door not staying shut was because the door had a slight bow in it due to heat and wear. And when I got it to stay shut, the actuator was barely engaging the interlock switch so it would intermittently indicate "front door open". I made the actuator on the front door longer by scrap plastic and epoxy. Its been good to go ever since.
            • tmaged
              • Oct 2008
              • 1890
              [ATTACH=CONFIG]44428[/ATTACH]
              Pretty sure mine had the rounded style. Thanks for the info !
              Hope that helps !
              -Tony
              www.dtios.com
