Kyocera 5053ci printing scanned documents
  • buzz
    • Aug 2013
    • 288
    Printing a scanned PDF on a 4551ci is clearer than printing the same pdf on a newly installed 5053ci.
    see the difference here:
    Color Print Job side by side_Page_1.jpgColor Print Job side by side_Page_2.jpg
    We ran the set up procedure MM952.
    Both machines printed off a KX PCL Driver.
    I also checked print settings and matched them to the tee.
    Any suggestions?
    thanks
  • JVergin
    Service Tech / IT Rep
    • 216
    Re: Kyocera 5053ci printing scanned documents
    Is that the same PDF file printed on both?
    If so,
    One easy thing to try next time you're there - in the printer properties, select the Imaging tab. Choose "Publications" under the Color Reproduction tab. Sometimes that gets rid of weird artifacts like that for me, though generally i don't see this on scanned documents. More so on clip art that's supposed to have a transparent background.
      [ATTACH=CONFIG]44439[/ATTACH][ATTACH=CONFIG]44438[/ATTACH]
      Any suggestions?
      thanks
      could it be due to resolution settings? a lower res PDF will print differently ... what res are you scanning at?
      • buzz
        • Aug 2013
        • 288
        If so,
        Yes, it is the same pdf file printed on both printers, and from same PC too (customer has one 4551ci and one 4053ci on the network). I thought I matched all the print driver settings but next time I'm there, I'll check again. I also tried to print using KPDL. But the customer did not have Admin rights to make that change.
        Thanks!
        • buzz
          • Aug 2013
          • 288
          Perhaps it is a low res document, the customer received it from an email attachment. But the weird thing is that the same file looks flawless on the 4551ci. ???
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1889
            Since it looks worse on the new machine, I'd wager it's in the document if you blow it up and look at it closely. The older machine doesn't pick it up, since it doesn't print as high a resolution as the new one. I had a customer complaing about the 4551ci we replaced their Sharp MX-4501N with. The Sharp printed their documents fine & the Kyocera had artifacts all around their logo. You could see it when you enlarged the PDF.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • copier tech
              • 8176
              Any suggestions?
              thanks
              There is a recent firmware release for the xx53 series check the notes what version are you on now?
              • buzz
                • Aug 2013
                • 288
                I updated to most current firmware. Colors were also off which compromised image quality, so I refreshed developer. Customer prints color two thirds of total meter, so all color developers are depleted of toner and not keeping density. Increased U147 toner timing from default +12 to +16. Quality looks good, we'll see how it runs over the long haul.
