HI EVERYONE....I NEED YOUR HEPL FOR KYOCERA TASKALFA 3010i
  • leo2020
    • Jan 2020
    • 3
    my coppy machine has 150000 coppy page its brand new, and i have this problem below in the photo with this dots...
    what i can do, what i can change ?
    thnx
  • Luther
    • May 2006
    • 682
    Re: HI EVERYONE....I NEED YOUR HEPL FOR KYOCERA TASKALFA 3010i
    clean or replace the charge roller
    • leo2020
      • Jan 2020
      • 3
      i have clean but its the same again[ATTACH=CONFIG]44645[/ATTACH][ATTACH=CONFIG]44646[/ATTACH][ATTACH=CONFIG]44647[/ATTACH][ATTACH=CONFIG]44648[/ATTACH]
      • KYO_OEM
        • Aug 2011
        • 684
        normally it must be MC.
        Please measure the distance between 2 dots.
        • leo2020
          • Jan 2020
          • 3
          [ATTACH=CONFIG]44649[/ATTACH]
          horizontal 37.5mm
          vertikal 15mm83388048_208221573544222_1796086410436935680_n.jpg82767753_592377708210364_3207396098213675008_n.jpg
            Originally posted by leo2020
            horizontal 37.5mm
            vertikal 15mm[ATTACH=CONFIG]44650[/ATTACH][ATTACH=CONFIG]44651[/ATTACH]
            no spacing from one dot (horz) to next dot
            • tsbservice
              Field tech
              • 7910
              37.5mm, it should be charge roller as Luther mentioned. Sometimes cleaning isn't sufficient you have to replace parts.
              • craigster
                • Apr 2016
                • 201
                roll your fingers on the roller and usually you will feel bumps on it. The steel usually corrodes causing the issue
                • campy
                  • May 2012
                  • 315
                  I had a similar problem on a 3500i and it was the charge roller.
                  • George J
                    • 107
                    It's my experience that cleaning the mc roller on kyo printers doesn't last all that long. Replacing them is the best option and easy to do.
                    • JRZ813
                      • Jan 2020
                      • 1
                      You can try cleaning the charge roller with a little bit of liquid car polish. Just make sure to only use a small amount and buff off all the residue before installing. Unfortunately if there's a Nick on the surface this may not help and it will have to be replaced.
                        • 22930
                        The earlier charge rollers with the bunny-brush cleaner would tolerate some cleaning. The newest charge rollers with the helical cleaner do not tolerate cleaning. Just replace. =^..^=
                        • rvptor
                          • Aug 2018
                          • 19
                          It is not visible on Main Charger, but it is definently MC....
                          • sisco
                            • Apr 2020
                            • 1
                            have to change charge roller
