PCL 5 DRIVERS FOR CS 3511i ???
  • Old Crow
    • Aug 2011
    • 201
    Maybe a dumb question but I'm no IT guy. Customer is asking if there are PCL 5 drivers for the CS 3511i in order for it to work with some older management software that they have. I don't see specifically PCL 5 drivers on the download center of the Copystar website. Anyone know if they exist or if the universal driver would be a good alternative?
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Re: PCL 5 DRIVERS FOR CS 3511i ???
    The universal drivers would be your best bet. If they're specifically looking for PCL5, you might have better luck finding a PCL5 driver for a HP 4si, then pointing that driver to the CS 5311i. It won't have extra features, like a finisher or extra trays, but at least it should output prints.
    • CWP
      • Jun 2013
      • 168
      Crow, if you use the KX driver you can set the emulation to PCL5e, or you can download the PCL5 mini driver from Copystar Central.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1863
        Like CWP said, install the KX driver, go into properties & click the PCLXL or PDL and change it to PCL5e.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Old Crow
          • Aug 2011
          • 201
          Thanks to all of you for the help, much appreciated!
            • 22979
            You wouldn't believe how many calls I've done because of HP LJ4 drivers:
            "Why won't my CS-C4035 print in color?"
            "Where did the booklet function go?"
            "Why won't it take paper from tray #3?"
            "Where are the job accounting settings?"
            I don't mind it for some temporary testing, but you can very easily end up with a 2500 page PostScript error printoff, one line per page, flowers smilies hearts ...
            • Old Crow
              • Aug 2011
              • 201
              Thanks for that advice Black Cat. One more question. I downloaded the KX drivers but can't find where you change the driver emulation anywhere. Tried looking in properties also. Do I need to actually be connected/add the copier to see this? I don't have a kyocera/copystar to add on my network, only Ricoh's.
                • 22979
                Yes, after its loaded. In properties ... maybe Advanced? I don't remember. =^..^=
                • darry1322
                  • Oct 2010
                  • 817
                  Bottom left corner of preferences has a box to select emulation on a job basis or you can set it as a default. Look for the image of the MFP.
                  • Old Crow
                    • Aug 2011
                    • 201
                    Thanks again to all for your help and sharing your experience!
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3945
                      X2 on not using the HP drivers on a permanent basis.
                      It sounds like a great idea at the time...but it WILL bite you eventually.
                      • Old Crow
                        • Aug 2011
                        • 201
                        Hi guys, so I installed an off lease CS-3511i yesterday and the customer's IT guy cannot login to the machine. I had him try 3500/3500, Admin/Admin and admin00. Are we using the wrong info. or I'm thinking because it's a used machine that previous owner changed the default password. I have seen some posts about entering prescribe commands but I am not familiar with this as I usually am dealing with Ricohs.
                        Short of performing a memory clear in service mode and re-entering all settings, is there an easier way? Or, are we just using the wrong login info?
                          • 22979
                          Yes, those are correct (3500/3500).
                          The PreScribe scripts are the best way to deal with this. =^..^=
