Ecosys M6630 Squeeking Noise coming from Fuser Area
  • Doug James
    • Jan 2012
    • 935
    [Misc] Ecosys M6630 Squeeking Noise coming from Fuser Area
    This machine has 35K copies. They run alot of envelopes so I am just assuming the squeeks are coming from the fuser. Is this a common problem or do the black drum units have this issue also (I just replaced the drum a month or so ago for lines)... Thanks so much for any help !!!
  • Happy Copier
    • Mar 2019
    • 45
    Re: Ecosys M6630 Squeeking Noise coming from Fuser Area
    There are people on here who know tons more than me, but every time we have a squeak it's usually the fuser
    Sent from my SM-G930V using Tapatalk
      • 22787
      I've had some luck with Uniflor 8172 on the fuser gear bores. =^..^=
      • JKISS
        • Jun 2015
        • 4
        car transmission fluid works good on the fusers. it can withstand the heat.
