4002i background
  • nathicana
    • Aug 2008
    • 335
    4002i background
    Having background intermittently on a 4002i. 130,000 counts on machine. Bottom in example is leading edge.
    Customer suggests it is happening through document processor only. Tech hasn't confirmed that. They don't scan so can't say if it exists on scans.
    Drum and developer unit have been replaced no change.
    Happens about every 150 pages. OEM toner. Firmware up to date
    Re: 4002i background
    lef or sef feed?
    have you used defect ruler to determine spacing between marks.
    • nathicana
      • Aug 2008
      • 335
      lef or sef feed?
      Long edge feed. No repeating marks that I can see in that direction.
        HUH? I saw TWO!
        • sparkycivic
          • Apr 2017
          • 348
          how come it doesn't go to the edge of the paper? is that sample a scan/re-print?
            defects when copying don't always E2E.
            • nathicana
              • Aug 2008
              • 335
              Yes, the voids look wrong. Paper feeding toward you in the example.
              It's supposed to be a picture of the actual print.
                if in the example.. the edge that is closest to me is SEF not the vertical LEF
                next time post in PDF not JPG format
                  • 23007
                  Yeah, there's a lot of confusion here:
                  1) Is this a print of a scan, a copy, or what?
                  2) SEF or LEF?
                  I'll be waiting when you know for sure. =^..^=
                  • nathicana
                    • Aug 2008
                    • 335
                    2) SEF or LEF?
                    Letter sized copy made using the document feeder. Feed direction is indicated on the example.
                    I'm thinking that the light source unit may intermittently not be in the correct position when the doc feeder is operating.
                      • 23007
                      Theres some logic to that. =^..^=
                      • allan
                        RTFM!!
                        • 5462
                        Some bad HV contact?
                        Whatever
                        • CWP
                          • Jun 2013
                          • 168
                          I'm thinking that the light source unit may intermittently not be in the correct position when the doc feeder is operating.[/QUOTE]
                          Nathicana,
                          I believe you are correct. Loosen the scanner drive motor slightly and also make sure scanner rails are lubricated and scanner slides smoothly.
                          • Hose1cook
                            Defective Technician
                            • Jun 2008
                            • 80
                            Have you confirmed it does not do it when you put the original on the glass? If not I would use the charts ( U411) to get it back in spec.
                            • JR2ALTA
                              • Feb 2010
                              • 2033
                              Originally posted by CWP
                              Nathicana,
                              I am trying this advice as well. I have a 6002i doing the same thing. I will follow up my results. The problem of course is how intermittent this is making troubleshooting very difficult.
