4002i background
  • moose55
    • Mar 2017
    • 143
    #16
    Re: 4002i background
    Originally posted by CWP
    I'm thinking that the light source unit may intermittently not be in the correct position when the doc feeder is operating.
    Nathicana,
    I believe you are correct. Loosen the scanner drive motor slightly and also make sure scanner rails are lubricated and scanner slides smoothly.[/QUOTE]
    When you remove the scanner drive motor you will find a "hidden" screw behind it. You will want to slightly loosen that one too. There have been 2 documented cases where this was the issue here in the US. (yes, one of them was at our office)
    The Moose is loose!!
    • kjg
      • Mar 2009
      • 111
      #17
      I have had two that have had that very problem. ADF only. It can be corrected by adjusting sim 68 to somewhere around +16.
      Just play with the settings in Sim 68 and see which direction makes it go away.
      • ABS tect
        • Sep 2013
        • 511
        #18
        It looks like someone messed with the density on copies...but that would be on the whole page
        I've seen it before on different copiers (so I don't know if it applies to this one) where the actual scanner unit corner is pressed down so its not level...
        • Gab
          • Aug 2015
          • 671
          #19
          Try a print if the problem vanish then the problem is at scaner ( clean optics, check and clean lamp etc) else clean with a brush high voltage board . If it remains replace it.
          Presume genuin toner
          • tee
            • Aug 2014
            • 79
            #20
            I saw this once on 6002i and it was the scanner lock position was in the shipping mode.
            I couldn't believe it till I took it out of shipping mode .
            Some installer screwed me.
