2550 ci slight shadow on lead edge of back side of copies and prints
  • wild140
    • Feb 2017
    • 70
    paper in letter portrait direction shadow from top to bottom ( not lead to trail ) varies from 1/2 " to 1 " on lead edge on back side of single sided copies.
    Not the drum or transfer belt .
    Any suggestions ?, Thank you in advance
    • 23007
    Re: 2550 ci slight shadow on lead edge of back side of copies and prints
    Do you have an image? =^..^=
    • wild140
      • Feb 2017
      • 70
      I do not . It is a very light shadow so I don't think it will show up on a scan anyway .
      • Santander
        • May 2009
        • 768
        If it is on the backside of a single sided copy, I would look at the secondary transfer roller to see if it is not being contaminated by a toner build up.
        • George J
          • 107
          My bet is the pipe assy that is blocked so the transfer unit cleaning is filled with waste toner that starts to build up on the transfer roller.
