Kyocera C356 Black box on legal
  • wild140
    • Feb 2017
    • 70
    Please see attached . It only happens on legal and is very random. It also seems to trim area under the box where there should be image
    One out of 100 , sometimes if two sets are run it will happen on one of the pages but not on next set.
  • Santander
    • May 2009
    • 768
    Re: Kyocera C356 Black box on legal
    The image you provided, is it a print or a copy? Would make a world of difference as to what is going on.
    • wild140
      • Feb 2017
      • 70
      Print
        • 22927
        I'm going to guess that it's a laser failure or possible image processing error. =^..^=
        • wild140
          • Feb 2017
          • 70
          Also replaced drum and updated firmware N/G , got spec ial reset firmware from Kyocera because of bad directions in SM about resets when replacing drum. No help
          • wild140
            • Feb 2017
            • 70
            The only reason I do not believe laser is it is very random , does not blow any codes and only happens on legal .
            Image Processing are we talking boards ?
            • KYO_OEM
              • Aug 2011
              • 684
              I agree with blackcat regarding laser.
              You can see sharp edges, sharp edges are related to LK unit.
              Have seen several cases because of some electric noise or broken laser itselfs.
              E.g. see Bulletin 2ND-0144(J190) from Taskalfa 4002ci because of electric noise on wiring
              Looks nearby similar to your problem.
              Have seen it also om Mercury range, on Tomcat range and so on.
              At these systems, exchange from LK unit solved the problem.
              J190_2ND_0144_SB.pdf
              • toddanderson
                • Dec 2005
                • 232
                I also think its laser, its making a black box and blank box , I think only a laser could do both
                  the fact that you got a NG when doing update leads me to believe you have a bigger issue to sort out.
                  you have to clear the NG before advancing onto other problems,
                  did you bother cleaning any sensors?
                  like maybe the ones on the belt?
                  clean all sensors.. try the Update and calibration adjustments again
                  • Tonerkiller
                    • Oct 2012
                    • 665
                    I think that the paper size is set wrong.
                      If it was paper size issues, it SHOULD happen on every sheet not a random. Right?
