Utax 3206ci fuser pressure roller bearings
  • outdoorkatie123
    • Feb 2017
    • 50
    Hi just wondering if anyone else having the same problem as ourselves
    We have had a run of machines UTAX 3206CI that the fuser pressure bearings are failing.The bearings are running tight and wearing the shaft of the pressure roller causing a build up of toner on the lower roller
    The machines in question are about a year old with roughly 100k
    I know that the fuser units are replaced under warranty but just curious if anyone else was having the same problem approx ten of our machines affected
  • KYO_OEM
    • Aug 2011
    • 719
    Re: Utax 3206ci fuser pressure roller bearings
    Not heard until yet.
    Maybe U000 saved by USB/ *.txt file can be helpfull for further analysing.
    If you don`t use "faked" toner, in normal case the FK-8350 will reach the expected lifetime.
