Ecosys M6535cidn
  • aAandy
    • Apr 2012
    • 370
    [CQ] Ecosys M6535cidn
    hello everyone
    attended this machine to fit 3 new color drum units & a K developer unit - upon completion K was super faint, so i reinstalled the old developer unit & prints were a bit better but nowhere near as solid as before and now you can barely see K at all
    heeelp!! any ideas?
    thanks in advance
  • JR2ALTA
    • Feb 2010
    • 2029
    Re: Ecosys M6535cidn
    Is it possible you didn't remove the plastic inlet cap from new the K dev unit? It won't add toner and will result in broken toner distribution auger in the transfer belt.
      +1 ya beat me to it
      • aAandy
        • Apr 2012
        • 370
        no, took that off, performed all the calibrations as per the instruction sheet, faint as - even when i put the old dev unit back in it was not as solid as before i took it out - checked and reseated everything, it has become almost unreadable
        driving me bonkers!! i'll check the ITB assembly and manually add toner to the dev with a funnel
        n.b. the colors are fine
        thanks for the response!
          Originally posted by aAandy
          no, took that off, performed all the calibrations as per the instruction sheet, faint as - even when i put the old dev unit back in it was not as solid as before i took it out - checked and reseated everything, it has become almost unreadable. driving me bonkers!! i'll check the ITB assembly and manually add toner to the dev with a funnel. n.b. the colors are fine. thanks for the response!
          did you check contact points and clean them?
          HVPS contacts?
          laser lens?
          transfer roller?
          throwing darts in the dark here brother
          • JR2ALTA
            • Feb 2010
            • 2029
            Drums are swappable. Did you try swapping with another color.
            • aAandy
              • Apr 2012
              • 370
              heading back there to try all of the above - anyone know the username and password to get into 'service settings'?
              • aAandy
                • Apr 2012
                • 370
                found the problem - thanks for the tips people
                removed the front cover (behind the bypass tray) and found yellow toner everywhere, it had arced, tracked and partially shorted - cleaned it all up and scraped out the arc track carbon - all good
                  • 22973
                  Congratulations on your success. =^..^=
