Copystar CS5052ci major copy quality issue
  • copierjeff
    • Jun 2015
    • 21
    These are going machine through landscape. Anybody ever seen anything like this? The samples are sky shots. The cyan and yellow have the bands
    going across page in same place every time. the magenta is light. I've tried replacing transfer belt, drum and developer units and HVPS. Oh and I swapped the engine board. Nothing changed.
    doc01619420200401093823.pdfdoc01619320200401093804.pdfdoc01619220200401093740.pdf
  • copierjeff
    • Jun 2015
    • 21
    Re: Copystar CS5052ci major copy quality issue
    Also, the bands start out at the lead edge. Solid area is trailing edge. Same place every time.
    • sparkycivic
      • Apr 2017
      • 348
      How is black? what exactly do you mean by "sky shots", I'd expect sky shots to be black, or an approximation thereof. Can you do sim 89 "sample set"? have you looked at the LSU units for cleanliness?
        • 23009
        Have you looked at the latent developed image on the primary transfer belt? Can the missing portions of the image be seen on the primary transfer belt?
        If the image on the primary transfer belt before transfer looks exactly like the image on the paper ... stop it sooner. What does the latent developed image look like on the cyan and yellow drums? =^..^=
        • Tonerkiller
          • Oct 2012
          • 668
          Looks like a laser issue.
          • GIUBOSS
            • 1436
            [ATTACH]45376[/ATTACH][ATTACH]45377[/ATTACH][ATTACH]45378[/ATTACH]
            we talk about copies? Have you also done an internal test print?
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Best not to do sky shot. Best solid black page on glass then select single colour gives a better result
              Regards Mark
              • Luther
                • May 2006
                • 682
                Replace the transfer board,just went thru this on the same machine, its a hidden board . you have to swing out the other boards to get to it
                • copierjeff
                  • Jun 2015
                  • 21
                  doc01619520200401142122.pdf
                  Here is status page. I made previous samples with sky shot on single color mode.
                  Black is actually fine.
                  • toddanderson
                    • Dec 2005
                    • 236
                    Looks like a transfer pwb , replace the transfer pwb and or check the spring contacts on the same pwb
                    [ATTACH]45380[/ATTACH]
                    • copierjeff
                      • Jun 2015
                      • 21
                      Thanks for all the help. it was transfer board. I really thought it had something to do with the transfer. I didn't even know that board was there.
