Kyocera Tier Color Monitor
  • kuby
    • Oct 2007
    • 1411
    Does anyone use the Tier Color Monitor to send their page counts to them automatically? If so how much does it cost? Is it per machine, per dealer ship license, or exactly how much does it cost. We have about 100+ machines and to get the page counts thru KFS. Log in to KFS and manually get them. Just looking at other options.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1898
    Re: Kyocera Tier Color Monitor
    What exactly are you looking to accomplish ? If the machine is set up for tiered color, KFS will import the meters into e-Automate for billing.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • kuby
      • Oct 2007
      • 1411
      [QUOTEhow Do you set it up and what does it cost?
      • tmaged
        • Oct 2008
        • 1898
        I think there is quarterly charge for each device on KFS. Your ASM should be able to help with that. Under downloads on KDACentral, Product Category KFS, there is a PDF on how to set it up to connect to KFS. You need someone that knows what they are doing, though.
        Hope that helps !
        -Tony
        www.dtios.com
        • copier tech
          • 8196
          If I may hijack this thread as I believe this is related.
          On the Kyocera counter list print out it has 3 separate colour counts & 1 for mono.
          So to work out the total colour count one must add these 3 colour together, no issue.
          However my question is it possible to just show the 2 totals on the print out total colour & total mono, a service mode U code perhaps?
          • kuby
            • Oct 2007
            • 1411
            Trying the machine at the shop and was able to get Tier Color Monitor to send the page count. Anyone know what the cost per machine is? Do you have to purchase a separate license for each machine?
            Have not heard anything back from Kyocera yet. We are currently using KFS and the people have to log into KFS and manually get the counts each month. Just looking at different options and see if is even worth the effort and money.
            Already have KFS setup and using that, just want to look a further options that may send the page counts automatically and see if they are worth it. The girls just wanted to know if there was a way to have the page counts sent automatically.
            • tmaged
              • Oct 2008
              • 1898
              No license required. It's definitely worth it.
              U332 is the code for Copier Tech. It's all in General Bulletin #97
              Hope that helps !
              -Tony
              www.dtios.com
              • copier tech
                • 8196
                Thanks is this correct?
                • tmaged
                  • Oct 2008
                  • 1898
                  Yes sir !
                  Hope that helps !
                  -Tony
                  www.dtios.com
