Kyocera 5500/5501 dark pages
  • geltrons
    • Apr 2007
    • 37
    Good day to all .
    requesting help to solve the below mentioned issue in kyocera 5500/5501 .
    for a single print or copy the, the quality is ok
    .but while printing and copying multiple pages, after the second page it start getting darker
    and darker and by the end of 10 th page it will be almost black .
    Tried by changing, Charger roller, Drum unit, developer unit, laser etc .( from working machine)
    we have 3 machines with the same issue .
    kindly help
    regards
    • 22997
    Re: Kyocera 5500/5501 dark pages
    Samples would be nice. =^..^=
    • Tonerkiller
      • Oct 2012
      • 668
      First of all, you cannot just swap parts around. When you changed the charge roller did you reset the counter?
      • GIUBOSS
        • 1385
        Originally posted by geltrons
        Good day to all .
        kindly help
        regards
        how many pages did the developer and drum of each machine? At each replacement, calibration must be performed. Is the transfer belt clean and also the exposure? Are all toners oem?
        • Gab
          • Aug 2015
          • 668
          Good day to all .
          kindly help
          regards
          Is toner OEM?
          Remove toner cartidge , make skyshots till message to add toner appears , put toner cartidge in and try some copies.
          • rvptor
            • Aug 2018
            • 19
            Non Genuine Toner
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              Originally posted by rvptor
              Non Genuine Toner
              and you are asking what's wrong?
              Idling colour developers are not healthy developers.
              • rvptor
                • Aug 2018
                • 19
                Everything is wrong with non genuine toner
                • tech07
                  • Aug 2008
                  • 409
                  Please provide sample pictures
                  • geltrons
                    • Apr 2007
                    • 37
                    yes charge counter is reset
                    • geltrons
                      • Apr 2007
                      • 37
                      Thanking all for the suggestions and replay.
                      The copy/print counter of the machine is around 400,000 pages for one machine and less than than for the second .
                      i have been using Katun toner for all these machines . it never gave any problem ( at least for me ).
                      charger roller is replaced and counter reset.
                      when swapping the developer crtb and drum crtg . developer and drum refresh and calibration is performed .
                      thanks guys
