print quality kyocera taskalfa 3051ci
  • Nikola Karamanov
    • Apr 2016
    • 58
    Hi everyone! I have this issue with taskalfa 3051ci only with magneta and black colors. I have done drum refresh, developer refresh and calibration but with no success!
  • craigster
    • Apr 2016
    • 201
    Re: print quality kyocera taskalfa 3051ci
    I would pull developer units and check mag rollers
    • kyotechnz
      • Mar 2019
      • 145
      Have had a fair few of this problem. When I see this I replace both the drum and dev for that colour.
      Never found out what causes this.
      • Nikola Karamanov
        • Apr 2016
        • 58
        The problem was from developer roller side, not from the drum!
          • 23009
          It's the developer spacers cracking. Magenta and black developing units will do the trick. =^..^=
          • kyotechnz
            • Mar 2019
            • 145
            I replace both because from my experience with this fault the problem reappears if I replace just the dev or drum. The local Kyocera rep couldn't tell me the cause but Kyocera has supplied replacement drums and devs as the copiers were still under warranty.
            • Ropariva
              • 679
              • Scott
                • 196
                Charge rollers
                  Originally posted by Scott
                  Charge rollers
                  already diag'd as dev units.
