Offset copies
  • jayw
    Sr. Service Technician
    • Jan 2020
    • 12
    [CQ] Offset copies
    I have a TA-6002i that is making off offset copies or residual images but it only happens first thing in the morning. The fuser and transfer unit has been replaced. The Regional tech recommended that I replace the Waste Toner Box(302ND94013) in the rear of the machine which I did. It seemed to have fixed the issue but if the machine sits overnight, the first 5 copies come out with the residual image then it clears up.
    Has anyone else had this problem?
    Re: Offset copies
    you need to properly register .. your profile is incomplete.. your terminology isn't accurate either..
    are you a tech?
      • 23007
      Re: Offset copies
      Samples?
      Residual images of what? previous prints? registration marks? something else? is there an interval?
      • Mr Magic
        • Jan 2020
        • 29
        Re: Offset copies
        Please provide more detail. Does it look like watermarks? Could be condensation! But still, would need to see!
        All the best!
        • jayw
          • Jan 2020
          • 12
          Re: Offset copies
          I got the terminology from the service manual. 5-11 Offset. This is what I believe is happening. I also checked the Repetitive Defects Gauge in the appendix of the manual. When I measured the defect, it appears as if it's the fuser which has been replaced.
          • jayw
            • Jan 2020
            • 12
            Re: Offset copies
            Also, I tried to register my profile but I don't know where to go.
            • Luther
              • May 2006
              • 682
              Re: Offset copies
              if the machine is in silent mode , turn it off and see if the problem goes away
                • 23007
                Re: Offset copies
                Do you have the appropriate media type set for the paper you're using? =^..^=
                  Re: Offset copies
                  Ok sent you a PM earlier today.
                  Follow that and answer in public forum here.
                  It will give us better info to help you
