gear code for cleaning unit transtert belt 2551 ci?????
  • avio2
    • Jul 2010
    • 150
    HELLO, I HAVE MANY BELT TRANSFERS WITH WORN RECOVERY GEARS USED DUE TO PIPE CLOGGING, DOES SOMEONE KNOW IF THEY ARE PROVIDED SEPARATELY?
    FOR UTAX NEED REPLACE ENTIRE T.B.U. BUT FOR ME IS ABSURD I HAVE MADE A FEW PRINTS azzo:
    • 23009
    Re: gear code for cleaning unit transtert belt 2551 ci?????
    Copystar and Kyocera both only offer assemblies. =^..^=
    • avio2
      • Jul 2010
      • 150
        • 23009
        Maybe you'll like it better in Italian:
        Copystar e Kyocera offrono entrambi solo assemblee. Non ci sono parti separate disponibili.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Problem will be waste toner pump its a problem on these machines
          Regards Mark
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Here you go
            Regards Mark
            • avio2
              • Jul 2010
              • 150
              therefore even kyocera does not provide the cleaning parts
              it was no easier to answer immediately instead of asking those questions from the top of your immense and relentless preparation????????
              • avio2
                • Jul 2010
                • 150
                Originally posted by mga
                Here you go
                this in the pipe , the problem is that when it does not drain, it causes the cleaning group to become clogged with consequent wear of the worm screw coupling of the cleaning group on the gear that I am currently modifying
                  • 23009
                  I'll take that as a compliment. =^..^=
                  • Calliem
                    • Jul 2015
                    • 14
                    if the gear didint break teeth,clean nit and glue them suckers on,or slide staple in under flat side of gear where it mounts to auger,they have a fail safe that reams the gear inside causing gear to roatate but not auger,mod and should be working like a charm again
                    • copier tech
                      • 8174
                      If you are using compatible toner you will get this issue.
                      You can not get individual parts.
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        Sometimes we have to replace parts transfer unit with includes cleaning assy will need replacing but they have modified the waste assy best to replace
                        Regards Mark
