Kyocera FS-2026MFP "Toner Cartridge Improperly Installed"
  • Cox
    • May 2020
    • 3
    [Error Code] Kyocera FS-2026MFP "Toner Cartridge Improperly Installed"
    I have tried multiple things and the error message is still there.
    1.) tried new toner cartridges.
    2.) made sure toner waste basket was emptied and cleaned components around it.
    3.)Removed drums and cleaned contacts of each drum
  • Copierstud
    • Nov 2019
    • 38
    Re: Kyocera FS-2026MFP "Toner Cartridge Improperly Installed"
    OEM toner? Make sure back door is closed.
    • JR2ALTA
      • Feb 2010
      • 2033
      Hopefully it's just this dumb fix. Check all the colors.
        • 23008
        If I remember correctly the left side sector gear operates the mechanism that engages the toner cartridges. If any of those gears becomes out of time or loses a tooth, you won't be able to insert the toner cartridge(s).
        It's no small operation disassembling and checking the engagement mechanism. I would do it in the shop. =^..^=
        • Copierstud
          • Nov 2019
          • 38
          It sure isn't, definently shop work. One tell for that is to lift the top cover up and down if not smooth and hangs up near the top and doesn't open all the way you are in for fun. But try the back door cause I have seen that as well. Also the back door actuator rod gets worn as well and wont actuate sensor correctly.
          • Cox
            • May 2020
            • 3
            YEEESSSSSS!!!! Thank you soooo muuuchh. I had been sitting on this problem for a whole year and tried nearly every possible scenario. (except this one)
            • Cox
              • May 2020
              • 3
              Thank you all for your time and help, I am extremely greatful for all of your assistence.
              • KYO_OEM
                • Aug 2011
                • 714
                remove right cover and high voltage pwb.
                Behind high voltage pwb you`ll see the toner container detection switch ( #21) in the upper left area.
                Open and close rear door and check if this switch would activated smootly by the lever interlock, which would moved by the door.
                You also can move this lever interlock by srewdriver.
                Open rear door and use screwdriver for pressing the lever interlock
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  My favorite part is not being able to test your work until you spend 90 minutes reinstalling everything.
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    Burned me too, my friend. But in the end they all get fixed.
