m6535cidn Horizontal stripes
  • jsproudman1
    • May 2020
    • 2
    [Misc] m6535cidn Horizontal stripes
    I just finished replacing a gear related to the paper lifter. If took about three months to find the part and many hours figuring out how to replace it. The consumables/drums were removed during this ordeal. The machine was plugged in for the first time in three months today.
    I got error codes for drum failure and developer failure. After fiddling with those a few times, it let me try to print.
    It is printing horizontal bars--just black if printing b/w, all colors in successive and repeating order if printing in color.
    I have tried vacuum-cleaning the drums and stuff and running all the cleaning programs in the U/I to no avail.
    Does anyone know if I broke something or if leaving it sit for so long was a problem? And, especially, how do I fix it?
    Kyocera Ecosys M6535cidn
    • 22702
    Re: m6535cidn Horizontal stripes
    You are learning about "light shock" the hard way.
    Drums are optical devices that are designed for short cycles of less than 1 second exposed to light, and less than 1 second dark. When you leave the drums in room light for months the drum becomes unresponsive to light, leaving blank areas crossfeed.
    SOME drums will recover a bit after repetitive copying cycles. You'll find out for sure after about 200 prints/copies.
    I suspect you'll be buying (4) new drums. =^..^=
    • Calliem
      • Jul 2015
      • 14
      replacing lift gears is a pain on those,check belt hv contacts from hvboard to contactors in front,seems like hv problem.
      • jsproudman1
        • May 2020
        • 2
        The lift gear was definitely a pain. Thankfully, I am the owner and so I can abuse it a bit. I cut a small bit of plastic off and removed enough screws to muscle it out.
        I don't know what the hv board is, but I'll look into it.
        Thank you, blackcat, for the tip. Next time, the drums will go in a box. Two days reassembled and it is now mostly printing correctly. No bars. The color is not quite right yet.
        I'm just trying to keep my machine running! I appreciate you guys!
        • sparkycivic
          • Apr 2017
          • 348
          this stye of print engine have given this fault described in other threads. source is HV instability/shorting. any overload of the HV will shut down and restart the HV system, resulting in pattern of heavy bars printed and no helpful codes generated. You will have to investigate the HV paths and contacts as well as all the charge rollers. There is a characteristic audible "chirp" that gives away the HV restarting phenomenon.
          • Ropariva
            • 591
