Kyocera 3050ci and 3551ci Magenta problems
  • bayshoreoe
    • Jun 2015
    • 44
    Hi all, have these two machines giving magenta background/repeating defects on copy and print jobs. Replaced magenta drums and dv units and problem still persists. 3050ci replaced ITB and machine worked for two weeks then problem came back. Only magenta on both machines. Anyone have any ideas/suggestions or answers for me.
    TIA
    Brian
  • GIUBOSS
    • 1385
    Re: Kyocera 3050ci and 3551ci Magenta problems
    TIA
    Brian
    all original supplies and even toner? charge unit? calibrate the transfer belt. Apply the black conductive grease to the tips of all four drum shafts. Check the cleaning unit discharge roller if it's okay.
    • bayshoreoe
      • Jun 2015
      • 44
      Compatible toner.
        • 22999
        Samples? Repeating interval? =^..^=
        • bayshoreoe
          • Jun 2015
          • 44
          I'll try to upload samples but background over ebtire page when it gets bad and drum and PCR are coated with toner and rotating the drum will not clean it off with cleaning blade, must wipe off toner with rag and will print fine for first few pages and then slowly start over again, some repeating dark bands from inboard edge to outboard edge, not repeating from lead edge to trail edge like a cylinder problem.
          Brian
          • GIUBOSS
            • 1385
            Brian
            Strange, if the drum units are new, the blade should clean the drum by turning it by hand, a minimum of friction should be there
            • tcook
              • Apr 2013
              • 37
              Compatible toner.
              Probably need to replace developer unit and use genuine toner.
              • Copierstud
                • Nov 2019
                • 38
                Compatible toner = crap toner. Kyoceras dont play well with "compatible toner". Agree with tcook.
                • JR2ALTA
                  • Feb 2010
                  • 2030
                  Unfortunately you can't get help here with compatible toner. It's not your fault but it's too big a red flag for us to waste time on.
