cc211 error code on bizhub c280
  • robikan africa
    • Sep 2008
    • 38
    [Dead] cc211 error code on bizhub c280
    Hi Twiz
    guys . i got a major one on Bizhub c280. I was deleting the machine users via page scope[web connection} and someone accidentally turned the machine off and when i powered the machine on again i got this error code cc211. with a message an internal error occurred. turn the main switch off and on
    i cant even go to service mode on the machine or log into pagescope on the administrator(admin Mode} as i dont have this password . I can only log in as administrator (user mode) with the 12345678. which only has machine status
    Anyone who knows how to go about this? Please help
    Robat
  • copier tech
    • 8131
    Re: cc211 error code on bizhub c280
    Originally posted by robikan africa
    Hi Twiz
    Robat
    This could be a HDD issue because they powered off the machine while data was being written to the drive.
    I would say format the HDD but as you can't get into CE mode this maybe a problem. Did you try the 9272 xxxx password?
    Try updating the firmware this may resolve the issue.
    • robikan africa
      • Sep 2008
      • 38
      Thanks for the reply..The 9272 does not authenticate. Let me try firmware update. Many thanks
