Kyocera Ecosys P2135dn Fuser dirty
  • bergerb
    • May 2020
    • 10
    Hi,
    I am running a printer in a very dusty environment.
    The last printer only lasted about 50k pages. Repetitive defects gauge lead me to the fuser.
    The fuser (heater roller) has some black dots on it, alcohol won't do it.
    My question now is - is there a way to clean it without destroying the coating?
    I am willing to try everything since I am not buying a new fuser for this printer.
    And if not - any ideas how to prevent this in the future?
    Maybe cleaning the dust out of the printer from time to time?
    Or anything I can put on the heat-roller to prevent stuff from sticking to it?
    Didn't find much on fuser-care on the internet, maybe someone could point me to the right direction?
    bergerb
    • 23006
    Re: Kyocera Ecosys P2135dn Fuser dirty
    I don't spend much time scrubbing fuser rollers these days, but when I did I'd drip some fuser oil (6 to 10 drops) onto the heat roller and warm it up several times. This softens up toner buildup on the rollers. Then while its still hot use a soft towel and an orange oil based cleaner to wipe it down, while rolling the fuser through.
    This is a great opportunity to thoroughly burn your fingertips, unless of course, you don't have any feeling in your fingertips anymore. Most of us that have been doing this for a while have burned our fingertips often enough that they don't feel much.
    If it's really bad you can repeat the procedure a second or third time. There is no point in trying to pass paper while there's fuser oil on the rollers. It will jam repeatedly.
    If you find scars in the roller(s) there's no point in continuing the cleaning. =^..^=
    • bergerb
      • May 2020
      • 10
      Wow, thanks
      Will be challenging to have enough heat at the rollers - with this model, the fuser is deeply burried inside the printer, but I will try my best
      Thanks again, that helps me a lot 👍
      • tsbservice
        Field tech
        • 8007
        Offtopic:
        Remind me cra.p Toshy model actually it was Sharp machine like Toshiba 161 maybe.
        They had terrible ghosting at around 20k so to turn fuser gear when fuser is hot I take fuser out plugged in harness while cheating switches to heat fuser out of machine then do the damn fingerburning job.
        I hate these.
        • bergerb
          • May 2020
          • 10
          I like the idea, that would make it a lot easier, thanks
          • Blizzoo
            • Aug 2013
            • 608
            Be very careful doing that with the fuser taken out without drive applied to the rollers. You can melt down the pressure roller to the heat roller if you leave it to heat too long.
            • Calliem
              • Jul 2015
              • 14
              [QUOTE=bergerb;1518203]Hi,
              bergerb[/QUOTE
              let machine predrive and clean roner build up with normal piece of paper
              • AL parts
                • Jun 2019
                • 61
                Wouldn't it be possible to replace the fuser roller directly?
                very cheap
                www.gzanling.com
                • Calliem
                  • Jul 2015
                  • 14
                  very cheap
                  there are after market kits available,but oem still best option
                  • jmaister
                    certified scrub
                    • Aug 2010
                    • 755
                    [QUOTE=Calliem;1521416]
                    Hi,
                    bergerb[/QUOTE
                    unfortunately, even paper is relatively "abrasive" if the goal is to maintain coating. Kyocera's coating isnt that good tbh...
                    and another thing to consider is machine's idle time to low power, how long does it take? I dont know if it matters on the smaller machines, but the bigger taskalfas fuser will only last 150k if the idle to low power is 1hr+. as to why, you are losing wear and tear to idle time. You may have only fused 150k sheets of paper, but the fuser has spinned 300k+ worth. Dont know if your case applies, but worth checking for future reference.
                    Idling colour developers are not healthy developers.
                      • 23006
                      +1
                      I recommend this to every user and set personal machines to 2 minutes maximum time to low power. It will triple the life of the fuser. If Silent Mode is available even better. =^..^=
                      • bergerb
                        • May 2020
                        • 10
                        Hi,
                        Do you mean the time it takes until the printer goes to sleep mode? I would say that takes about a minute.
                        Worked really well, didn't remove everything, but I got a lot of the toner removed.
                        And after that repeating error was fixed, my printer decided to smear toner all over the place (drum was dirty after one print job) so i cleaned the drum cleaning rubber thingy and now I have nice white pages
                        Thanks for all the help!!
