taskalfa 4551ci bright color printer
  • pasek2051
    • May 2019
    • 24
    Hi everyone. I'm in the dot, my kyocera prints and scans as if it had eco mode on. I replaced the laser and developer and drum cmyk modules. Anyone seen something like this?
  • Ropariva
    • 694
    Re: taskalfa 4551ci bright color printer
    [ATTACH=CONFIG]46223[/ATTACH]
      • 23010
      There are lots of scanner settings:
      DPI resolution
      original type
      background
      monochrome/color
      eco mode
      What settings are you using?
      Try some of the other settings.
      • pasek2051
        • May 2019
        • 24
        I replaced the dv and dr transfer belt with a used one from another good machine. I was doing u21 and updating the firmware. the printouts from the machine's computer and scanner are faint colors.
          • 23010
          Explain to me please how a drum or developing unit could cause light scans.
          I need to know. =^..^=
          • pasek2051
            • May 2019
            • 24
            • pasek2051
              • May 2019
              • 24
              my English is poor. I have repaired a lot of such machines but this is my first problem.
                • 23010
                • pasek2051
                  • May 2019
                  • 24
                  will express more clearly. scanned image to computer is ok, copy and print are bad. Don't look for a problem that doesn't exist. please help with printing the machine.
                  • Ropariva
                    • 694
                    Eco print is clearly enabled from your status page. Disable eco print and perform drum and dev refresh then calibration followed by tone curve adjustment. This WILL solve the issue.
                    • M94
                      • Jul 2020
                      • 158
                      Ropevira is right friend, the image you posted clearly shows that ecoprint is on, and it seems likely that could cause this issue. Best of luck, please let us know if you solve the issue and how.
                      • pasek2051
                        • May 2019
                        • 24
                        Eco print is off, I checked if there was any difference on it. Eco print turned off has the same effect. Refreshing does nothing.
                        • M94
                          • Jul 2020
                          • 158
                          Then perhaps a charge issue? If the drum(s) are being charged past what is expected it could cause less toner to be attracted to the drum, leading to a faded image overall. Not sure what the best method to test this theory would be.
                          • sparkycivic
                            • Apr 2017
                            • 348
                            My vote for troubleshooting is on secondary transfer poor efficiency. check that the contact spring as well the contact pad at the rear of the door for debris and deformation.
                            The rear pad and spring gathers toner or other dust and will bleed current from HV causing low transfer efficiency.
                            try stopping the copier during a print, and look at the transfer belt exposed face, is the image dense, or faint? and does image remain on the belt after it has passed the secondary, and returning toward the left side of machine(top of belt)? Then the secondary transfer isn't good.
                            • pasek2051
                              • May 2019
                              • 24
                              Finally, some solution. I will check and let you know. Thank you
