taskalfa 180
  • Gab
    • Aug 2015
    • 671
    taskalfa 180
    PAper jam freequently at section above fusing unit . Any idea where the problem is?
  • Ropariva
    • 676
      • 23008
      Re: taskalfa 180
      I think the problem is that you didn't specify a jam code. =^..^=
      • Tonerkiller
        • Oct 2012
        • 668
        Re: taskalfa 180
        The exit section got bridle over time on these. I do not think you can get parts for them anymore.
        • Gab
          • Aug 2015
          • 671
          Re: taskalfa 180
          jam codes 41, 46 and 21. Also at the attached files (at note here) there is a dark line not from drum or corona about 3 cm before end of paper as it exits copier. check the letters (letters look bold and condensed)it looks like paper has a delay at this point when it is on drum.
          Any idea?
          HAs it any connection with paper jam?
