Taskalfa 6002i
  • Brandon
    • Jun 2019
    • 72
    [Error Code] Taskalfa 6002i
    Good morning
    I received a machine in our workshop with a machine failure call service 0180 on the screen , i ran the U004 and after that i am now getting a 0150 error referring to eprom, any assistance please
  • Ropariva
    • 694
    Re: Taskalfa 6002i
    Has it had a board swap? EPROM not on the board or inserted wrong way round?
    • Brandon
      • Jun 2019
      • 72
      Re: Taskalfa 6002i
      The board was not swapped and yes the eeprom is in the correct way
        Re: Taskalfa 6002i
        Is there another EPROM on this machine? main and engine
        • pascalb.
          • Aug 2016
          • 47
          Re: Taskalfa 6002i
          Hello
          I recommend going to SIM 004
          and check the serial numbers
          Engine & Main
          imperative the Engine number must be the machine number.
          that's it?
          Do not lament,
          do not mock,
          do not hate,
          but understand.
          • lees
            • Apr 2011
            • 95
            Re: Taskalfa 6002i
            Use a genuine Kyocera toner cartridge in it. Many generic toners will cause this error. If you are using a genuine cartridge, try another one.
            • pascalb.
              • Aug 2016
              • 47
              Re: Taskalfa 6002i
              Yes on the range which does not use the RFID technique, it is a direct contact by springs.
              If the chip on the cartridge breaks the 3.3V circuit, you get C0150 or F040 because no more communication between the main and Engine !!
              But there if in SIM 004
              Engine serial number ****
              I am thinking of the Eprom or Engine card.
              Do you have a serial number in SIM 004?
              Do not lament,
              do not mock,
              do not hate,
              but understand.
